Is GM Vortec 454 essentially the same thing as the 300-HP L29 7.4L?
That'd work. Really not bad engines. A definite step up from the old peanut port 330 flat tappet engines. The cam in them is factory installed retarded like 7 degrees or something like that. I suppose if you were gonna do the carb, then maybe slap the 454 mag cam in it if you can find one cheap. They're 9:1, I actually think with the mag cam, intake and carb it be a pretty decent running engine!
Anyone think it will run at all with the 800 Holley on it, or will it fall on its face? I don't really care if it revs much past 4600 RPM - I just want to have the boat running for the remainder of the summer. I'll be getting the cold shoulder from the wife and kids if it's not running in time for our lake trip in July.
I also have a line on essentially the same engine in an early-90's Fountain. Guy bought the boat thinking it had 385 mags in it. One started knocking - bad wrist pin. Pulled it and found out it was an L29 out of a Suburban. Remaining engine was still running OK, but not sure how much use/abuse it has had. However, it is possible for me to hear this one run before buying it.
Putting the mag cam in it, would be a pretty good comparison of the vortec head setup vs the GM rect port head setup. The compression is close to a 454 mag, slightly higher.
The truck L29 was rated at 290HP. The marine version 310HP. The marine setup had a different intake/injectors but same internals.
I have a engine masters issue here. They tested several carbs ranging from 650-950cfm on a 372ci small block with some good parts.
The highest HP AND torque was with the 950.
AVG HP/TQ from 2500-6000RPM.
600CFM Holley DP 380HP/428FT lbs
650CFM Demon 374HP/421FT lbs
750CFM Holley DP 383HP/430FT lbs
950CFM Holley DP 387HP/435FT lbs.
All carbs were mechanical secondary.
I built my L-29 up using the .510/.540 magnum cam and it runs awesome! It has a little more rumble at idle but has excellent torque at 3,000 an above. I bought the cam for less than $200 and got a new single row timing chain as well and it was pretty cheap. I did install larger valves and did some minor, basic port cleanup but I think the gains were very small from that. Use a nice air gap dual plane intake and throw that 800 carb on and enjoy the summer! TBF
