502 Mag cooling system problem
My water line from thermostat housing to water pump is blowing off above 3500 RPM. The engine is running cool. Do I have a head gasket issue or thermostat housing obstruction to bypass circuit? Also, can I remove the thermostat without removing anything else?
Just remember, EFI engines like heat. If it is in tact an EFI, you will soot the transom, get terrible fuel economy, and most likely wash the oil off the cylinder walls.
