Power Steering Pump Issue
Took me two seasons to finally figure out my PS issue..turned out to be the low pressure return line..had a small pin hole leak in it, and would cause the fluid to leak out and cause problems. I would just check, or replace the line, its simple to do, esp since you said you seen fluid in the bilge sometimes..
diagram and parts list there was a seal rebuild kit that is no longer available for the control valve. Is this a common issue for this old type steering assembly
