Does the 72C use the same tail housing for #5 drives and TRS drives?
The tail stock for the TRS is smaller in diameter where it slides into the transom assy. The shaft diameter on the input of the drive is different.
If you are looking for a #3,4 or 5 tail stock; I have 1 left. If you find some worn out ones, they can be rebuilt with all the bearings, sleeves and seals from Timken.
