prochargers and boost >
Old 09-17-2013, 06:49 PM
  #31
Received 4,314 Likes on 1,241 Posts
Its the river.. if it was ran on the lake all would be fine.. the river is a jinx!!!
ICDEDPPL is offline
Old 09-17-2013, 06:52 PM
  #32
Originally Posted by MILD THUNDER
Smitty, CNC, What are you higher boost guys running for plugs? Heat range wise.
Also, what is your target AFR at wot?
anyone?
MILD THUNDER is offline
Old 09-17-2013, 06:53 PM
  #33
yep,and the lake water is colder.
mike tkach is offline
Old 09-17-2013, 07:55 PM
  #34
GPM
The M5 cooler might work a little better than the 4.
GPM is online now
Old 09-17-2013, 08:21 PM
  #35
NO WAY! Those intercoolers are magical! You can run 40psi on 87 octane if you have one!
+1!!! and you have to feed the intercooler off the water crossover that is mounted to the engine which also goes through a oil cooler b4 it even hits the engine....this wat you have all your base's covered lol..no need to lwp's this way and no starving the cooler of water either..
FIXX is offline
Old 09-17-2013, 09:08 PM
  #36
anyone?
-9's low to mid 11's.
WETTE VETTE is offline
Old 09-17-2013, 09:12 PM
  #37
Wow!!!! Where you been hiding!!!! Someone told me you've moved on from the go fasts and are working part time at bass pro shops in the rigging dept? Lol
Craig , what's your thought on a projected tip -8 plug with 15psi?
Old 09-17-2013, 09:13 PM
  #38
perfect!
Old 09-17-2013, 09:14 PM
  #39
I won't run a projected tip plug on anything with a power adder.
Old 09-17-2013, 09:17 PM
  #40
And yes I have slowed down temporarly. The Kings like a 2.5-3.2 troll so thats were I'm at. Still plenty of motors to tune and friends to give me a ride from time to time.
