gen 6 engine filling oilpan with water.
#31
Somebody else had a problem like this and it ended up being the head gaskets. Something about core shift in the block left a very small sealing surface between the mark IV heads and the Gen 6 block even with the proper gasket.
#34
on the run stand it had app 12 lbs,in the boat i saw 23 lbs,that is not excessive pressure.i put 35 lbs of air pressure and cannot detect a leak.tomorrow im going to get some dye and put it in the radiator on the run stand,then im going to run it to 180 deg,then im going to pull the intake&heads and see what i find,then im going to jump off a tall bridge.well maybe il skip the bridge jump.
#37
Fast Singles Club
