502 losing oil pressure >
Old 10-07-2013, 05:17 PM
whiskeyhangover's Avatar
I had the same problem and it was spun crank bearing. Motor ran fine believe it or not and it finally blew after a complete summer of running it. The temp ran kinda hot a little over 200 °. I would get it checked out.
whiskeyhangover is offline
Old 10-07-2013, 05:56 PM
I think I figured it out. I now have 45-50 psi at 900-1000 rpm idle. And yes, it was something really really stupid. I don't think I can elaborate further. It is just plain embarrassing!!!!
Baja226sport is offline
Old 10-07-2013, 06:01 PM
On a motor with clearances set right ,10# per thousand is what gm used to say (bbc) .That being said ,I don't want to idle under 20#'s and the way pumps work , the pressure will rise faster than 10#'s per 1000 throttling up, until you reach the pump blow off pressure. Usually 60 + #'s with the blue spring. Running too much pressure cost power and wears pump / distributor gears faster than necessary.
motor is offline
Old 10-07-2013, 07:34 PM
Full Force's Avatar
Shim pump for more pressure, that was advice years ago of Gellner..... hes not new to boat engines... I never wore anything out doing this, ...
Full Force is offline
Old 10-07-2013, 07:52 PM
You expect to get off that easy around here?? spill it!!
phragle is offline
Old 10-08-2013, 08:05 AM
Enquiring minds want to know. You have to tell us. Believe me, no one on here will judge.
TPro587 is offline
Old 10-08-2013, 09:52 AM
VoodooRob's Avatar
You could save a life with your information & think of the children my good man, think of the children!
VoodooRob is offline
Old 10-08-2013, 10:18 AM
97FASTech's Avatar
I have only 15 - 20 psi at idle (750), maybe I have your problem also? Please elaborate, or at least PM.
97FASTech is offline
Old 10-08-2013, 01:07 PM
Come on - spill it !!
ALL_IN! is offline
Old 10-08-2013, 04:28 PM
Trust me no one has this problem
Unlimited jd is offline
