Gen VI 496 builds - Stock oil cooler adequate?
Did he have oil temp gauges before the most recent rebuild? If nothing else in the build changed, as far as compression, camshaft, etc, and just the 4.25 crank, I'd guess he will make about an extra 30hp. With that being said, a cooler from a HP500 engine or similar sized, would probably be adequate. I don't think the stock 330 cooler would be enough, if hes boating in warm water and running water thermostats.
I'm thinking A-pillar pods mounted to windshield frame!
FWIW, I built a Gen VI 489 and ran the stock 330 HP combo oil / PS cooler on it. However, I did go through the extra effort of eliminating the remote oil filter mount and lines, and went with a thermostatic oil filter sandwich adapter and #10 AN lines to the cooler. This eliminates almost all of the sharp turns and restrictions that the stock lines will have. IMO this is even more important than the cooler capacity. I generally saw temps of around 185 - 190* when cruising, and it went up to around 225 - 230* if I leaned on it. I generally do not run mine WOT for more than about 5 minutes at a time, and even that is rare. Most of the time I run between 3000 - 4000 RPM. If your buddy likes to run his at WOT for extended time periods I would recommend the bigger cooler and also better lines and fittings, especially in water temps that are that warm.
As far as a gauge, could he mount something under the hatch and just check it after a hard run? That would at least let him know if he has an issue. A low cost solution would be to just aim an infrared temp gun on the oil pans after a hard run. Hell, a buddy of mine came up with an interesting low cost / low tech solution that he ran for a while - he drilled a hole in a pipe plug and epoxied a digital oven thermometer into the hole. Gave him a reading on where he was at so he knew whether he had an issue. Of course he replaced the plug after this - I would not trust JB weld in a critical application like this. Of course, the down side to not having an oil temp gauge is that you don't have a real time reading - sometimes disaster can be averted if you shut it down when you see the oil temps starting to get too high. Bearing problems and water in the oil often show up this way before making themselves apparent in other ways.
Trust me Gentlemen, I've already been in his ear about adding oil temp gauges. Given that we don't know what his oil temps were prior, and the fact that he is going to what we estimate will be 500 HP 496's, can an educated guess be made ahead of motor installation if bigger coolers are needed? Obviously it is much easier and cheaper to change coolers now that the motors are out. Would going to cross-overs with lower temp t-stats have any significant impact on oil temps with the stock coolers?
Did he find the issue that caused the one engine to hydro? I would be more concerned with making sure that was corrected. I completely understand that adding gauges and bigger coolers would be difficult at best after installation in a twin engine boat. That's why it's probably best to do it now, versus find out the hard way later, especially if he likes to lean on it.
Did you make any other changes to the engines other than adding a 4.25 crank? Or, how much power does the new engine make?
I personally wouldn't run my oil temp at 250*. With my Merc HP style oil thermostatic filter heads, and a bellhousing plate cooler, my oil temps cruise at 180* all day, and when I run hard, they go to 210-215, no higher. Absolutley no condensation issues.
Saved it to my "boat engine" file. Good stuff!
