Scatt 9000 crank BB chev >
Old 01-12-2014, 10:51 AM
Pirate of the Chesapeake
Fenderjack's Avatar
Default Scatt 9000 crank BB chev
Any one ever use one in a build.Look to be a little better than stock.Thinking a one for a mild 496 build.JOHN SR
Fenderjack is offline
Old 01-12-2014, 02:03 PM
Fenderjack's Avatar
ttt
Old 01-19-2014, 05:28 PM
Fenderjack's Avatar
ttt
Old 01-19-2014, 06:05 PM
finscreenname used one on his 496,,then did it over again,,i would spend the extra money and go forged..look into the f43 if they make them for big block yey..super lite..
FIXX is offline
Old 01-19-2014, 09:35 PM
Thebossbultsma's Avatar
I put one in my 496 stroker and it has been great for me.
Thebossbultsma is offline
Old 01-19-2014, 09:53 PM
John,
Personally, I would spend a few hundred more and get a forged crank. If you were sticking with a 4" stroke or it was going in a street car, then maybe. I wouldn't do it with a 4.25" stroke. But that's me. I just don't think it's worth the little bit of money saved for the loss of sleep worrying about the crank. Just my opinion.
Eddie
Young Performance is offline
Old 01-19-2014, 11:48 PM
Damn Mike busted my balls before I could answer.
Nothing wrong with a Scat crank for a build under 600hp. Yes I smoked my first 496 build because I used the wrong bearings. Standard bearings rub the shoulders of the crank and filled the motor with metal and spun a bearing. Live and learn.
f_inscreenname is offline
Old 01-20-2014, 10:28 AM
Fenderjack's Avatar
Was just curious.Have used the 9000 series in some small block builds. I know there better than a stock cast iron crank,and stockers will take a beating.Like I said mild build 088 large oval port heads if I can find 2 pair cheap!! hyd flat tappet cam single carb.For a my friend JOHN SR
Old 01-20-2014, 04:11 PM
blue thunder's Avatar
I ran them a number of years in my 500ish hp na engines. Then added blowers and moved up to around 650hp and snapped one between the 4/5 main caps during 2nd season with blowers. I'd spend the extra for forged as well, you never know down the road what may be done to the engine hp wise.
blue thunder is offline
