Low frequency vibration...
I have a new to me 99 Baja 302 Boss with twin 454 Mag MPIs turning Mirage Plus 25s. Idling it sounds and feels perfect. In and out of the water (on a hose). Took it around the lake for a couple hours everything was as it should be. Stopped to float for a little bit, when we began to take off the boat shuddered, is the best way to describe it. I backed off the throttles and the shudder stopped. Tried it again and it acted just fine. Nothing else remarkable that day. A week later idled out of the channel into the bay began to take off and the starboard engine shuddered horribly. It felt like a displaced u joint, it was that bad. I backed off and idled the rest of the short trip.
I have removed the out drives and the u joints seem to be in 100% condition (the dealer said all maintenance was done but I was skeptical). The prop hubs are not new. And that is on the list to change.
Does anyone have any suggestions as to what I should be looking for?
Thanks in advance.
Thanks in advance.
The props are in good condition. No lines or any foreign material around the shafts. The hubs seem to be a little loose but I intend to replace them soon.
Could .015" clearance between the hub insert and spline adaptor cause the above condition?
I did attempt to isolate the problem. No luck that way, everything seemed to be OK.
Although I was able to I visually inspect the starboard coupler through the gimbal bearing. I can see a definite delineation where the rubber meets the metal insert.
Now I am going to attempt to change the coupler without pulling the motor out. Fun fun!!
I really appreciate the input!
