Pro charger and carb Info
I was told by both manufactures that the only coast guard approved method of a blow-through carb application was with a box and if you had a fire your insurance co would not cover .
1 Post
does your megasquirt throttle body have a shaft for the throttle blade or blades because if so you still may have some fuel leakage under boost.the deal patric from pro systems sells for carb apps with a hat consists if modifying the carb and a plate under the carb.it is a really neat deal.
