leaking header
Boats an 06 ,so i guess that puts the repair thing from cmi out.I pressure checked today and even though it's leaking obviously in a tube ,it isn't where it can be seen with soapy water from either end .It's one header from a set of twins .The others look and test fine.Will CMI sell just one header?
Charter Member#568
I found a skilled local welder who did a great job for much less money/ time and no boxing/ shipping. I was able to find a couple options locally. Check around. CMI didn't mention age when I spoke with them, but said they won't fix it if they can't see it. If you just used air pressure to check, re check it with water and you might notice it easier.
Straight bottoms and flat decks
