What fuel would your run
The last motor I just built is for e-85. It's 12.3 to 1 compression. We ran it in our racecar for a few yrs and it a lot better and way cheaper than race gas. I have never saw a prob with fuel lines yet but I always use the push loc hose that's made for ethanol, methanol. I agree with some and would use the 93 and if u had to use the other.
I've had a holley carb eaten away because of using ethanol blended pump gas.
The ethanol absorbs water and corrodes the crap out of bare metal parts.
Since then I use stabil in everything.
In talking with my carb guy in regards to using e85 in a race application, he warned me to buy known quality (55 gallon drum of rocket brand e85) as the ethanol content of "pump" e85 is all over the place and as such, the octane rating varies greatly.
i know with e85 you can turn the boost up without worry of detonation because the octane rating is around 115 but in illinois you never really know what you are getting when you buy it.i have heard it can be from e60 to e90.how is the consumption,i would think mileage would suffer compared to 10%.
I have run into many problems with Ethanol. It has been with carburetors - remember, they have fuel tanks open to the atmosphere too, it's called bowls - and believe it or not it has been more with billet aluminum bowls, metering blocks without any coating - so yeh, more BG carbs than anything else.
Within 6-8 months, they've become nasty. A few carbs I did back to back years.
Stabil, startron, filling fuel tanks, empyt fuel tanks...didn't matter. It was within the carb that had problems.
I am in Northern New England where we get huge temp and humidity swings. Boats are left outside...non garaged.
How I fixed the problem so far ? A member from here and mostly another forum told me about removing fuel water seperator during winterizing, and filling back up with a 2cycle oil / gas mix.
Run engine until blue smoke comes out the tailpipes and wallah, carb bowls are full (well, 1/2 full cause of floats + N&S) and no more problems. Upper cyl walls get 'fogged' to boot.
Works for me and just so you know. I had about 20 carbs here after the first year we got introduced to ethanol in our area.
Sucked being one of the only one's that new how to do carbs.
Here's a pic (not mine) of exactly how the inside of these carbs looked. Scary !
Only difference, the carbs I add, again especially the Barry Grant's, where full of much more than this:
It's not sludge in the carbs I did....it's a form of electrolysis. In person it's more of a white granular jelly. Even the fuel bowl screws had major pitting where they are exposed to the fuel.
One of these carbs, I had the bowls off a few times for it's last week-end running. Cold weather, High pressure, it's the last day of the year, we don't care if it breaks as much, tuning for highest MPH day.....sort of thing. LOL.
First start next spring,,,,,pop,pop, fart,,,sputter. Take carb apart and fall over.
Remember, fuel bowls are roughly half full and exposed to the atmosphere (air/humidity/temp) thru vents.
BTW: Most engines I've worked on (perf mods) have another inline filter installed right before the carb. These you can take apart quickly and check it's fine metal screen. No debris.
My carb way a holley and the metering block took the hardest hit.
Found a much better picture. What I saw was just like this, mine had just a little more 'jelly' consistency. But same deal.
Sorry, won't post as a pic, can only provide a link. Prepare to fall over: http://forums.boatfreaks.org/showpos...9&postcount=29
