Baffled by apparent reversion issues with Lightning headers and mild cam
#41
I think it is the nature of the beast on these headers, I have the same and can tell they get water back in, as you know I did the water bypass on mine trying to get the 02's to live, F on that...but they dump water so close to the collector don't think you can get around it...I'm running a 500HP carb cam and know they are iffy on reverting...I talked to lightning as well and they warned me against my water dump idea, but we ran and checked one side with valve open bleeding off water and the other closed in stock position and did not show much temp change from one side to another, but that was about 20 mins running...still want to test some more...Rob
#42
IMO, the whole silent choice thing is nothing but a royal pain in the azz. We have more than enough options today for sound control. Air operated mufflers, full time clamp on mufflers, muffler inserts, turndowns, etc. I'd throw those silent choice diverters in the dumpster, and have someone make full jacketed pipes thru the transom and throw some mufflers on it.
#43
I have Stainless Marine TRS dry to the tip manifolds. (3' of tail pipe) When I pull my O2 bung plug they will revert water back to the manifolds. The those need to be sealed good. Also I have never seen dry stock lightning headers at an idle. I have to agree with ezstriper.
#44
If I were going to modify mine I would consider adding a dump outlet on the separate collector and close up several of the water ports on the top. Might just do that before the season is over. Any good welding shop could handle it, and I could easily cap off the dumps if I decided not to use them.
#45
I just removed the drains off the rubber log that feeds the tubes, installed a simple shutoff valve there(they were different sizes on mine) and I just drilled and tapped my Y pipe 3/8 pipe, not hard, ran a line from the valve to a fitting there, you can adjust how much water you bleed off...talked to Bob M. about this and he liked the idea of getting as much water as possible away from the engine...
#46
I talked at length to Jan at Lightning, and he thinks I am pulling water in at the joint. These headers were originally designed for silent choice, but the slip in collectors are used for larger cams. He said to use silicon to seal that joint and see if that helps. He did not seem to think limiting water flow to the headers is an option, but many on here would disagree I am sure. SB, what modifications would you recommend on those collectors? I was seriously thinking about welding a bung on them to dump excess water and then close up a couple of those holes up on top. I agree that it does not seem like an optimal design to me, and I can't see where that much water out the exhaust is needed to cool the hoses and the tips.
I would have an inner pipe made/welded in that is as long as you can fit with a slash cut - top longer than bottom. A 3 1/2" iner with 4" outer (outer can be rubber or metal).
The bravo pumps mover so much water that your exhaust won't burn thru if using rubber and the 1/4" or so gap from outer to inner won't have a smooth ramp for water to get sucked back as easily as most companies risers do since they roll/flare the inner pipe OD to outer pipe ID with water outlet holes of course. That's too smooth of a transition and thus does nothing to deter water from going backwards.
Alot of people in the small block and small boat world - smaller pockets in this boating category - do....even with stock or cheap GLM exhaust - ie: weld inner extensions on to the outlet of the inner part of risers. Bam ! No reversion, or , a ton less. Edit in: typically 3" inners and 4" outers as small blocks don't need more than 3", and the added bonus more of a step between the inner and outer where they terminate.
Get the water introduction further away and make it harder to come back up backwards. This is what has to be done before modifying water supply, overboard dumps, etc,etc as these should be final straw if needed.
Your cam is mild !!!! Just get all water away from the area just after the inner collector starts.
#48
You have a point, I can see condensation in the breather tubes, and it's barely reading 120* on the gauge. However, I was able to look up into the pipes and see that they were wet all the way up to the primaries, so there is definitely some water backing its way up the exhaust.
