Need some help guys! Just bought a new boat.
that is the standard mount. problem is I don't think it'll fit on those plates. and the height of those plates is probably off too. they may well be set up so that the bracket between the 2 3/4 inch nuts sits right on or a little above those brackets. about 3 inches too high and about level with the rear mount pads.
Thanks for the pic Jim! Those look like the lower mounts on my warlock. The mount on the Daytona is just a single hole with no stud. I'm guessing I'm just gonna have to try it and see if the alignment is right. I've just never seen an upper and lower mounted like this.
I'm thinking the same thing Derek. It's just a strange mounting set up to me. I'd do offshore mounts but between the procharger and accessory alignment it would be a pain in the butt!
