What do you clean your boat with?
Get the least expensive toilet bowl cleaner that you can find - a plastic garden sprayer - goggles and rubber gloves - spray the bottom of the boat let it sit a few minutes (maybe 5-10) and hose off-- what some folks do is put the boat on a trailer - spray it - let it set for a few minutes and then launch - NOT THE BEST FOR THE ENVIRONMENT. I even do the engine to some degree - but I rinse that off much quicker. I have been doing this for 30+ years and NEVER had one ounce of a problem -- in fact I have our boat on a lift but just being in the water for a few hours will put some yellow on it - I typically spray the bottom 2-3 time per season.
as with ANY cleaner try a small spot to make sure you don't screw up the finish
Safe Boating
3pointstar
Safe Boating
3pointstar
The Works toilet bowl cleaner or Sno Bowl work great. The easiest way is use a spray bottle or pump garden sprayer.
Muratic Acid works very well also. It is a little harsher if you breath it in.
Rinse very well after using any of them. All of them will stain an aluminum trailer or diamond plate so cover with plastic if needed.
OSO Moderator
All the stuff mentioned above eats a bit of your gel every time u apply it.
Read this thread: http://www.offshoreonly.com/forums/g...-easy-use.html
This is what to use!! It works, non acid based, and won't eat gel, skin or have nasty fumes. It works!
Hard part is finding it. A local marina around here carries it, Norfolk Marine in Norfolk, Va.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Yes, once you apply something like Works to your hull you will be cleaning it more and more often as the staining reappears quicker. Not sure if it removes some of the oils in the gel or makes it more porous or both. The freshwater lake I boat on is a nuclear power plant cooling lake. A buddy of mine that slips his boat next to me has worked at the plant and says they put something in the water to help lubricate the seals for the cooling water pumps and he thinks that exasperates our hard water/staining problems.
All I know is in my experience my boats stay pretty clean the first couple seasons then the staining/deposits appear. After the initial cleaning with acid I then have to clean the hull at least twice a year. So the acid does something to the gel.
I use MaryKate On Off. Works in seconds and brings the worst stains all the way to factory white. Sure it strips wax and I have even read that it strips the factory wax from the gel. I figure why fight it since the boat sits in a slip and no matter what you do you will have to strip and re-apply wax anyways. It's unavoidable.
