Riser gaskets...which one? >
Old 07-15-2014, 09:26 PM
Default Riser gaskets...which one?
Replacing riser gaskets, which do I order. Boat is in fresh water with only raw water system. Restricted or not?
inthetundra is offline
Old 07-15-2014, 11:32 PM
I would go with the non restricted.
f_inscreenname is offline
Old 07-15-2014, 11:47 PM
BUP
Not to sound like a jerk but what in the world do you have ? Mercruiser, OMC, Volvo, Indmar, PCM, Ilmor ? And the next question what exhaust system do you have stock or aftermarket, what year model is this and serial # of your engines. It would be throwing dice as to what to throw back at you without knowing exactly what you have. Just saying. If I call the auto parts store and ask them for an exhaust gasket what would they say ? The same exact questions as I just thru at you.
BUP is offline
Old 07-16-2014, 07:06 AM
1988 Mercruiser 454 mag. stock manifold and riser to thru hull exhaust
