Measuring Compression Ratio
My typing must be invisible. LOL.
SB, I read your response quoted from the website (which I already looked at). Thats like saying how does a car engine work...easy, you turn the key and it starts....haha. I was just wondering if someone knew what measurements it takes, like it measures how much air to pressurize the cylinder to a certain psi at TDC and then BDC and can then calculate the chamber volume somehow?
MarineKinetics
SB is correct, the vast majority of the Whistlers were utilized by sanctioning bodies (SCCA_NASCAR_APBA etc) for validation of CR in the field (competition events). In the shop environment stacking tolerances works equally well. See Katech spec sheet attached.
Bob
Bob
