oil spray from the front of a new 502 motor custom built
i hear you loud and clear I will talk with my nephew and figure this all out the last thing he needs is that i live in ct lower fairfield can you point me in the direction of someone that you know that is good at this
thank Dino
thank Dino
One question the oil bypass valve you said 11lb what should be in there or should it be removed
oil cooler is on the right side looking at the motor the sea water inlet is on that side and feeds the cooler first before the water is drawn into the motor by the magnflow pump off that will not self prime another issue i need to look at. oil filter screws onto the block
Ok so i started to read more and man this sucks, so there is a special bypass valve for a motor with a oil cooler also we are only running one oil filter a fram ph30 should we have two a is there a better setup for this
Would going to Norwood, MA 02062 be too far ? Those guys build/rebuild standard and performance marine engines like this all day / everyday.
no its a open system cooled by seawater, i ran the oil through a paint screen looking for metal oil didn't feel gritty either, the oil that came out was the brake in oil that had about 2hrs on it and sat in the motor all winter
