Looking for advice
Thanks, Alex told me a possible reason for engine sounding sick when I bring it back to idle is because the O2 sensor got wet which made the computer add a bunch of fuel down low. Other than that data logs looked good.Going to check compression tonight.
#3 = 140psi #4 = 152psi
#5 = 140psi #6 = 60psi
#7 = 100psi #8 = 155psi
So if it has 380 hours, does it still have stock head gaskets? I always change them when putting a blower on because the stock gaskets just can't take the added cylinder pressure. I would put the starter on and get the water out then start it, as others have said.
Yes Stock HeadGaskets. According to the people I bought the boat from the motor has never been opened up. I cranked all the water out and oiled it up good yesterday.
