Fuel supply issues >
Fuel supply issues
Fuel supply issues
Old 09-11-2014, 01:41 PM
different intakes will signal carb differently so you really must jet to your setup, are you not running the carbs that were run on the dyno ?
ezstriper is offline
Old 09-11-2014, 02:27 PM
Originally Posted by nitrouspaul
check you metering block gaskets if its been apart and look for dirt in the bottom of the emulsion tubes too.
I did find some debris in one emulsion tube and a broke off drill bit in one...and a another broke off drill in the other block. It looks like it was poorly modified for more orifices in the emulsion tubes.
JRider is offline
