Inexpensive 454 mag performance up grades
#32
I agre with all that replacing motor with low hour from forum is the least expensive and best way to go, that been said, i opted to restore boat, make it a real pretty solid boat first replacing what was needed and upgrading everything replaced with an eyt to performance., you need to have your boat ready **before** you add big hp and speed.
That is why the previous poster asked about steering.
My pre motor replacement will include: Proper gauges, full hydrolic steering, k-planes, performance outdrive (mine alpha) bolster then a real motor. Several 540's have passed the classified section lately 550-650 hp under $8k then sell 454 to offset cost.
Again situations and need for speed, to finish varies amoung us all.
Lots of luck. Look foward good to follow progress.
#37
Keep in mind that even the Bravo 1 is vulnerable to HP levels above 500. Especially the early model Bravo's, even more so with a lot of hours on them. If you plan to romp on it, plan on going through it and possibly upgrading it for more strength, or find yourself a spare to have sitting at the ready for when it goes kapow next summer with 650 HP running through it.
