SBC Built, now looking for jet recommendations
Do you have a provision on your exhaust for an o2 sensor to use an AF gauge? It's the only way to tune a carb these days. Many manufacturers are making adaptor plates to use sensor in their exhaust.
Does anyone have any experience with a D.U.I. Distributor? One came on my boat and I'm wondering if it's a weak link.
If you have the Merc dry joint exhaust you put an O2 spacer between the manifold and riser. O2 sensor is in the dry section of exhaust at this point. Lots of folks do it. You will be asking yourself why you didn't do it earlier once you can monitor real time AFRs. No guess work if its ignition or fuel related when you run into problems. No plug reading BS etc.
You can also use the Holley Plate that also holds the Throttle Morse cable too as an added bonus if you don't have your cables set up to your carb yet.
Edelbrock #2732
Holley with Morse cable attachment set up
BTW: if you get the plate from Edelbrock, the gaskets are paper. They suk.
I use a open spreadbore gasket under plate, and open squarebore gasket on top of plate.
Mr gasket's gaskets are decent and cheap.
Too funny: I just opened my carb base gasket bin and guess what was at the bottom. The Edelbrock sealing plate. LOL.
Wags Engineering http://wagsengineering.com/products/...sensor-spacer/
or
Dennis Moore's http://www.ebay.com/itm/OXYGEN-SENSO...-/310137061646
I have both, either will work. Wags has a nicer finish but not passages around the sensor so water can pool on the top side of the elbow. I currently run Dennis Moore's spacer. There are good pictures of the installation on his eBay page.
I also run the MTX-L wideband shown.
As a technique I also drain the manifolds at the end of the day.
or
Yup, and you need the sealing plate for the squarebore (Holley) carbs. 100% fact. Or vacuum leaks will plague you.
Edelbrock #2732
Edelbrock #2732
Im also using Mr Gasket carb gaskets. Both ontop of the plate and on bottom
or
or
like this: (top of picture)
Have you taken out plugs to see if wet from water ? Or removed a manifold to see if water is being pulled back in /
I have 0 experience with that exhaust set up.
BTW: I absolutely dispise cheap EBAY chinese ignition components, as you know, and you are changing.. Not a big fan of MSD stuff Marine, but that's a dependability thing many run into some years down the road. Some don't.
