700 sci - over heat at high rpm only
Did it ever smoke an impeller? If so, were all of the pieces found? They can make there way into the coolers and heat exchanger and really plug them up. I would install a new impeller and housing (if needed) and start removing water hoses and back flushing them. You can remove the end caps of the oil cooler and check it for obstructions.
Eddie
Eddie
