Need engine advice N A 598 cubic inch rebuild
#65
It was 598 valve head broke off.
Now 600.9 cubic inch
Dart block 4.610 bore
K 1 tech 4.5 crank original
K1 H beam rods orginal
Dart intake 1050 Dominator
Comp. cam 11-461-8
308-314-112
10.7-1compression
Basically used the block,crank,rods and head castings everything else is new
Comp. cam 11-461-8
308-314-112
10.7-1compression
#68
Same as the orginal cam. I like how ran and sounded. Is there a reason you ask im always willing to listen and learn.
#70
