Need engine advice N A 598 cubic inch rebuild
#72
Can you explain more about why 5, 6, 7
#75
#77
on some of the dyno's you guys run on,it probably is,,for others w/ more accurate ones,not so.I just did a 600 w/ 357 afrs and got to 740hp,of course I kept the lift .675" so the valve and springs weren't getting changed every other year.and the engine idles at 800rpm.
#78
i like to use this to weed thru magical hp claims w/ cylinder heads
http://www.wallaceracing.com/calcafhp.php
