Why do larger roots blowers use 2 carbs?
Curious why the bigger roots stuff use 2 carbs. Is one large carb possible? Such as a 1050 dominator in a 6-71 style blower. I have a 525sc with a weiand 177 and am trying to figure out if a blower upgrade is worth the effort.
articfriends (12-16-2023)
Fuel distribution is part of it. The main thing is when you start pushing through more air, you need more fuel and this can only be accomplished with 2 carbs.
I don't even think they make a single carb plate for anything larger than a 250/256 blower.
I can tell you first hand the blower upgrade is worth it . Been there and done it.
Twin carbs doesnt mean more fuel. A 600hp engine tuned right should use x amount of fuel whether it has a single 1050 or dual 850s .
I have twin 850s on my engines. This summer i had a linkage problem causing the secondaries on one carb to not open all the way. I lost 1 lb of boost because of that. Roots like lots of available air
More Air , Less Pumping Loss, and Better Fuel Distibution.
You can use it. I know they do make an adapter plate. I think youll find youll run out of carb before you run out of blower. Many guys have tried this since the 60s. Theres a reason 99 percent of 671 amd larger blowers run dual carbs. I woukd even prefer dual carbs on a 250 blower and its only about 60 percent of the size of a 671
