Valve Springs & Rocker Arms - 525EFI's ???
Already had one motor rebuilt this season due to a failed rocker arm around 200 hours. My 525's now have about 230 hours on them and just to be safe I'm planning on replacing the valve springs and rocker arms this winter. I would prefer to replace the stock Crane rockers and PAC springs with better quality components.
Any recommendations for both?
I hate the winter!!
Neil,
I agree, call Bob Madera. I am sure he will have a direct replacement valve spring for your 525's. Most likely, it will be Isky. Are you planning on pulling the engines this winter? If not, I doubt you can get the valve springs replaced with the headers on. You may have to reset the installed height to match the new springs. Depends on what the new spring height will be.
As for rocker arms.... I would think that a set of Comp Pro Magnum would do well for you. You may have to change your push rods as well, to get the geometry correct again.
http://www.compcams.com/Products/CC-...kers%27-0.aspx
I dont think the "PAC" is a bad spring, or the Crane Gold is a bad rocker. Seems like the issue with the 525 stock setup, is too little spring pressure. Eddie Young has rebuilt plenty of these, and the stated the spring pressures are quite low. When you do not have enough spring pressure, the valvetrain can no longer control itself. When that happens, $hit breaks. "PAC", is a very good spring, but the best quality spring in the world isnt gonna if it isnt setup properly though.
I learned years back that ISKY springs, are made by PSI. Both good springs, but under the "isky" label, they have much more spring rate selection. Seems like the PSI label, is more suited for high RPM drag stuff.
Bob M, or Eddie Young, can provide you with the proper spring "SETUP".
As for the Crower stainless rockers, they are a great rocker. A bit more money than their aluminum counterparts, but they will last a long time, aluminum has a fatigue life.
All metals have a fatigue life. Im not going to speak for bob, however, mercury marine actually did extensive endurance testing for hundreds of hours using the scorpion marine endurance rockers. To my knowledge they are the only "validated" rocker for a marine endurance application.
Some of today’s steel rockers are just as light if not slightly lighter than a comparable performance *aluminum rocker. Steel can safely handle a lot of valve spring pressure, up to 950 pounds or higher say the people who make such rockers. Steel has better fatigue strength and stiffness than aluminum, and will stand up to the rigors of racing for a longer period of time – often 2X to 4X as long as comparable *aluminum rockers.
