Fuel Filter
I use a bulkhead style mount with a WIX 33522 water separator/filter with -8 lines and I pull through with my mechanical pump. I boat on big water and don't want to be stranded because I got some bad gas. It's a big filter but definitely worth it. It has a lot of filter area and filters down to 10 microns with a drain to check for water.
Reason for checking is for electric fuel pump set ups. They don't pull fuel worth schit as we know, however to have a filter/seperator before the pump usually increases height the fuel has to go before pump can access it.
So, inline prefilter before electric pump, pump itself, and then to (usually up to) a water/seperator filter seems to work fine. Just make sure the sperator/filter is rated for the psi given, even thoug most are.
