Carb talk
You get a fuel "dump" when the PV restrictions are oversized. The powervalve or power enrichment circuit is not rocket science. When its boost referenced you won't have a "dump" becauase you can tailor the amount of fuel the power valve adds easily on a quick fuel carb. The main reason not to plug them is, in my opinion, an issue at low speed when airflow thru the venturi is weak.
I agree with ya on the dyno thing!
I have a question for you guys, I think that everyone so far the has responded to this thread, has a roots blower with carbs that are mounted sideways. So, have any of you checked at what angle they are at while running wot or Idle????? Mine are at 6.7* at idle and at 7* at WOT (depending on water conditions). And it just happens to be that 7* is perfect angle of trust for my setup. Well that don't work out the best for the float levels. Believe me put angle finder on a float bowl and see how much 7* lowers the low sides of the bowls. Maybe it wont make much difference, but I bought 6 two inch carb spacers and am milling them at 7* so when I m at WOT or idle my carbs will be flat level & can set float levels right on. Also the stock car boys have special floats for going around left turns all there lives. They are wedged on the G force side. I was thinking of installing these also, for rough waters running, getting on plane etc.... What do you guys think??????
Yes MT, I have the stock bowls and the way you described is exactly the way I did set them, but its still not perfect, so I opted for angle milling some carb spacers. I guess it can't hurt. its only money & time right??? LOL
Ya, once in a while when idling through a no wake & hitting others wakes... It would tend to flood a little (black smoke)...thinking it was coming through the back boosters. I didn't want to lower the floats cause I didn't want any fuel starvation at the WOT. So if figured angle plates & be done with it, the carbs will be level and close to perfect fuel level. It just at to cool to wash your rings down... Same thing probably happens when getting on plane. Although, my boat gets on plane without tabs in about the length of the boat.
