benefits of distributor-less ignition
#71
you can,,I have 2.only problem is the body is plastic and some think it may not be strong or accurate enough for higher lift cams.high lift cams need more spring pressure and may screw w/ the pick up in cam sensor body while driving the oil pump and such.
#72
MarineKinetics
do they make one for a 58 tooth?
#77
I just don't see it. The only thing I could see that would have an effect on the housing is the oil pump and the fact that the cam gear is going to try to pull the distributor gear into itself. The steel shaft in the housing is a steel shaft in either housing. Spring pressure is going to twist the cam and change the timing regardless of what the distributor housing is made out off.
#78
#79
this is just a touch better.been on the fence for years on doing the conversion.just haven't found a need yet.
http://www.jegs.com/i/Chevrolet-Perf...60247/10002/-1
#80
thats a good price but
