Couple quick questions
When these seals start leaking it's not because the sealing lip has worn out. It's because there is a spring inside the lip that losses it's tension. If you are good you can remove the seal take the spring out shorten the spring to get the tension back re-install and good as new. I've done this many times in a pinch. When customers needed to get on the road and a seal wasn't available.
I usually put a thin coat of rtv(on outside of seal) for insurance and help it slide in too, it should push in pretty easy,but they prob dont recommend it
http://www.offshoreonly.com/forums/g...-build-up.html
Rtv on the outside of the seal is not a good practice especially on the seals that have the blue sealant around the seal. The rtv has a chemical reaction with it and will not dry properly. In a case where there is a lot of pressure the seal will push out. The best thing is to clean the outside of the seal with lacquer thinner and install.
Just sharing some hard earned knowledge. I replaced a front seal on the same Cummins 3 times before someone informed me I was the one causing the issue. Of course, they waited until I finished my long-winded rant about junk seals.
http://www.summitracing.com/parts/cc...12oaAg9z8P8HAQ
Used hundreds of these successfully.
Well, it's in. Used your method mike of raising the crank slightly but I did install basically dry.
Hoping to get the pistons in this week so I'll be back for more questions shortly. Thanks!
