Would you guys use this?
whats the history on this engine?any blow ups?
When i put bearings in i clean the back side of the bearing and block/rod woth brake clean and a towel that wont leave anything behind. Then i put the bearing in and clean the face of it the same way. Then Put assembly lube on the face and assemble immediately. Assembly lube and oil attract dirt out of the air and it will collect .
Cranks undergo serious distortion under load. David Vizard went as far as to claim that line hones aren't really necessary on budget builds because the cranks distortion under load makes it trivial.
