Procharged 502 Mag Oil Cooler Recommendations
I am having Eddie do my fuel system which requires the elimination of the cool fuel and pump.
Is there an oil cooler that can go in place of the cool fuel? I will pick up the thermostatic adapter to run with one if I can get it to fit.
Seems like a good location.
I plan on putting my new cooler in that same location. I purchased 2 of these http://www.cpperformance.com/p-13327...r-bracket.aspx to hold the cooler to the existing cool fuel bracket. I am sure it will involve some cutting and grinding on the existing bracket. I recieved my new cooler and it is monstrous compared to the tiny fuel cooler.
When you get it done will you snap a few pics?
I am still a month away from tearing down.
[ATTACH=CONFIG]537444[/ATTACH][ATTACH=CONFIG]537445[/ATTACH][ATTACH=CONFIG]537446[/ATTACH]
Mounted the cooler today. Fuel Cooler bracket works great for this. Even the factory holes lined up for bolting on the Stainless mounts. Only fabrication left to do is weld a couple of the unused factory holes shut just because I am being picky.
