cnc d heads
#44
Originally Posted by 14 apache
Psi springs will se how they do CT1542DML Damper 1.580" 1.155" N/A .755" [email protected]" [email protected]" 513 .070" .780" 1.200"
My old cams where 276 284 with .750 after valve lash. these made peek 6700 rpm,
I ran the same cam in my Procharged 598 with BB2Xtra and then Big Dukes, did you run the above mentioned springs with it ?
#50
And I was wrong about the cam, it was a Comp Cam 276/284 @.050 .782 lift.solid roller. Crower 68806 springs with the 2xtra's, 68848 and then Pac 1348 with the Big Duke.
