Garage door issue...
Ok...not something normally found on a boating forum but since we reach a large cross section of boaters from all over...here goes.
We have a two car garage with a Liftmaster Garage Door opener that like most others, uses a laser beam across the opening to prevent the door from closing in the event something crosses the beam while the door is closing. Over the past few days at about the same time every morning the door won't close as if something is interrupting the light beam. In each case there is nothing in the path of the beam.
Understand this is a new issue and has never happened before. Now get this...in the afternoon...the damn thing works !!! It works at night also...just not in the mornings between 8 & 10. I thought about the sun and it's unique angle this time of year so I tried standing in different positions to cast a shadow on the light receiver that gets direct sunlight...makes no difference. I have tried re positioning the location of the beam with no effect.
We have only had this happen this past weekend...usually we are up and away early during the week so we don't have the sun up and everything works fine. Even though here in SE Florida we have beautiful sunny weather this time of year as compared to most other parts of the country, we still have the same short days and long nights until March 21st when the days start getting longer than the nights. This doesn't happen during the summer when it is daylight when we leave.
Has anyone else ever experienced this and have any ideas as to how to remedy this situation?
Thanks in advance.
Thanks in advance.
Try giving it a helping hand as it closes, if that works then its time for a little maintenance. I have a screw drive that doesn't like to close when it's cold.
I had that problem at my old shop but it was the sun and when I shielded that side where the sun came in low the prob went away. it does not take much light to trigger the sensor and its the direction i believe that does it and sunlight rays are nearly parallel at that distance. it was seasonal and at times it was bad enough I had to bypass the sensor. another solution would be to rotate your property and buildings about 90 degrees
08 OPA High Points Champion
Send me a plane ticket and I`ll open the door for you, dam -9 this morning.
As for cold...how about 55* LOL
It's definitely the sun...guess I'll have to come up with a way to shield it....maybe a toilet paper spool or something similar...I don't know...
