wix oil filters
I wouldn't run the R filter. The micron rating isn't low enough to filter your oil effectively .
The R filter is for someone that changes there oil very frequently ( such as a race engine ) .
You will be hurting yourself in the long run. Someone mentioned the 51794 ( 2 Quart Filter )
That's what I would run if you can fit it, the filter media is about twice as long as the 51060.
Less pressure drop , more flow , increased filtering capacity. Ive used the 51794 on 800HP Sprint Car Engines
without any issues. Buy a filter cutter from Jegs or Summit and look insde the different brands , you'll get an education!
Unless you running large volume dry sump oil pumps , that need the volume ( GPM ) .
