rocker arm stud diflection
#94
I do know of someone that broke the rocker boss out of a Dart aluminum head that was ported paper thin (Dick Tryce) BUT wouldnt you think if there was a "problem" with the stud boss on Tinkerers head it would have broke right out of the head, I assume your saying the stud boss might be cracked?
#96
it might just be the camera angle. But even if it isn't there isn't much that can be done since the push rods are almost hitting the intake runner. If memory serves me I had to do a bit of grinding to get the clearance that I have. I would have to move the rocker stud over to get the rocker centered on the valve stem. I will go out and take a close up look at it.
#99
I cut & tig weld the guide plates to where I want them, and they should be. I don't trust the nut & cap screw that comes with the adjustable guide plates. I have yet to see a BBC that the guide plates didn't need some or alot of adjustment.
