ARP head bolts for 525EFI part #
If the threads engage 1 1/2 times the diameter of the bolt, then that is as strong as it will be. Any more than that does nothing.
Eddie
I did some double checking on my bolt lengths and found that they only are going to be engaging the block 5/8". Except for the 4 dowel pin bolts, they'll engage 3/4". So with a 7/16" bolt they should engage 10.5/16" to get full strength. I called ARP and they found a set a little bit longer so I ordered it to see, they are a longer than factory mercury bolts so they'll probably bottom out so there a no go. So my question is am I being too critical here since Im 1/2 of a 16th shy of 1.5 times bolt diameter thread engagement? With the head gasket I may be a full 16th shy. I considered ordering the stud kit but thought Id ask that question before doing anything. Thanks
