What fuel pump for a 502 making 600+hp.
I am running EMI Thunders with the 16 inch ss tops. After that there is a short run to the back of the boat(7inches). Its wide open in the back. I am dumping a ton of water and was thinking it could be choking off my exhaust?! I do have stock stuff in the tank as far as I know. I do have a fuel pressure gauge on the duel feed line to the carb. I think it is saying 7.5 ish if I can remember.
At the dyno last year we did the brake-in runs and after the first two pulls the shop owner pulled the exhaust off and switched it out for a brand new set of headers. He claimed no way that motor made that HP from what I told him was in it. After tell him the work into it and not just bolt on parts and an exhaust change we pulled again. Loads of tuning a day later we got her dialed in and I got a handshake. Good job son that is one heck motor for your first one.
So after searching on OSO and finding that guys said this AIRTEX 90632 worked I have to say that its not TRUE. I looked it up and it only has 1/4 inch threaded lines in and out. I have 3/8ths. What pump do I need? The old one is a carter 0-2208? This is driving me nuts.
CV products makes a complete pump.. SPIN-MP-2600
Or use a Mercruiser or Airtex top half and change out the bottom half with a CV products one or a KE...
http://www.cpperformance.com/p-12460...6-engines.aspx
I used a CV Bottom half I got used from a Winston cup team... Looks like the part number is cv5505-2
Thank you for the good idea. I am going to toss in my gopro and put the old crap back in for a fast test run. Since I am three miles from the ramp a quick spin will reveal all. Fuel pressure and see if the pump seals are weeping.
You can download an app for your smartphone which will allow you to use your phone as a remote monitor and start / stop recording.
I have a 502 I punched 10 over making 600+ on the dyno. We made many pulls to 5500 rpm with more to go but I would not let the shop owner keep going since I was not going to be running more then 5250 max. OK so on the dyno we used his fuel system (electric pump). I came home and put the stock bravo raw water pump on the motor with the mech fuel pump. No mater what prop I put on I could not get over 4700-4800. Well I always change the impeller every year and found gas in the pulley oil this year. So time for a new fuel pump.
One thing we never talk about because I don't think anyone has checked, I'm suprised I haven't either, is since the sea water/fuel pump is belt/pulley driven, what it is driven vs crank speed.
A regular block mounted pump is 1/2 engine speed because of being driven off a cam lobe.
If the sea wwater pump is driven faster than 1/2 crank speed, we'll get more pumping action.
Anyone wanna measure crank pulley diam and sea water pump diameter to come up with fp driven speed ?
