502 mag mpi? >
502 mag mpi?
502 mag mpi?
Old 05-28-2015, 06:09 PM
Originally Posted by dbkski
The early 90's EFI engines used a different flame arrestor, such as you pictured, and will not work on your 1998 502. If you have the
serpentine belt set-up like my 1999 502
then you need the style below. The two styles of flame arrestor mount differently.
http://www.knfilters.com/search/prod...x?prod=59-4542
I got my assembly from Dana Marine years ago. I did some testing and lost 9 RPM's at 5000 RPM's using the K & N filter.
I bought the assembly for better filtration since we have a lot of bugs and cottonwood trees around my area.
My bad I guess that part didn't register when I read it!
What?????
As stated earlier my engine is a stock 1999 Mercury 502 Mag MPI. I tested with the stock flame arrestor, none, and the K & N.
Using the stock one actually allowed for the highest RPM's but since the numbers were so low I consider it insignificant.
Thanks again for the info!
Diamond Dave is online now
