Questions about big power >
Old 06-10-2015, 06:37 PM
So 1100's it is. Thanks for the replies
snapmorgan is offline
Old 06-10-2015, 06:51 PM
cigrocket's Avatar
Smile
Of course one of those packages should be hooked up to #6 Drives and the other could have XRs. Big difference in initial cost, fuel is the cheap part. In my old Top Gun that I had, the 875HP weren't bad on fuel until the boost gauge started to move, then the gas gauge had a Vacuum effect. lol
cigrocket is offline
Old 06-10-2015, 07:29 PM
The fuel cost is probably negligible compared to engines and drives.
hogie roll is offline
Old 06-10-2015, 08:35 PM
Yep, 1100 boat has 6's
Old 06-10-2015, 08:44 PM
Oops - saw that you already have your Advantage up for sale - did you sell it yet?
Budman II is offline
Old 06-10-2015, 08:51 PM
welcome to the big leauges!
mike tkach is offline
Old 06-10-2015, 09:12 PM
Shocked no one brought up carb vs efi...guessing the 1100's are carbed where as fuel efficiency goes way down compared to an EFI setup with the 600's. Think you'll be shocked how thirsty carbed 1100's are even without the boost.
1MOSES1 is offline
Old 06-11-2015, 01:21 AM
Received 1,821 Likes on 907 Posts
Hmmmmmm???????
There are 2 stiletto's for sale. One with 650's and one with 1100's
Griff is offline
Old 06-11-2015, 01:39 PM
Yep,, the 1100's will burn more fuel than the 600's, heavier engines w weight of the blowers,, heavier #6 drives that require more power to run the same speed compared to XR'S..
Maybe I'm wrong but do the #6's create more drag in the water, less aeordynamic.? than XR's
Your Advantage Mid Cabin you have for sale is in Mint Cond. ,I have seen it.
253 is offline
Old 06-11-2015, 05:17 PM
I have not been actively trying to sell it, but I think I will start.
What is a Stiletto? wink wink
