Bravo dual water pick ups
Getting ready to put a nose cone on a bravo dual water pick up drive. Drive is standard length. Can I block off the low water pick up without hurting anything? if so would u fill the low water holes in before putting the nose cone on? anyone done this before? Thanks for the help.
I have high water pressure and cant get motor to warm up with thermostat was hoping by blocking that could get temp up in motor and water pressure down a bit. Thanks
I would tap and plug the holes with pipe plugs first. Then experiment running it to see if it helps.
If you don't plug them first, water will seep back down and cause the nose cone to get water under it and it will prob crack.
How high of water pressure???? Do you have a crossover??? I think you may be trying to fix the issue the wrong way.
Thanks for help ill try that first. Before I install nose cone. If I have no problem then I should probably close those holes off permanently before installing nose cone, Thanks
