7.4mpi with cmi headers which gaskets >
Old 07-07-2015, 11:07 AM
Default what gaskets you guys using on headers
So I installed these cmi headers on my 7.4mpi's custom fabricated tails and I used Mr. Gasket copperseal header gaskets thinking they were better than the other options and learned the hard way that they suck. All 4 headers are leaking at the flanges. Now to pull them out and reinstall them with new gaskets is another day or so wasted.
What gaskets do you guys recommend?
Should I go with the extreme duty gaskets they sell at Hardin marine or some regular felpro gaskets from the local auto parts or what do you guys use???
ivanfuego is offline
Old 07-08-2015, 10:13 AM
I would use Fel Pro 17440, do not have personal knowledge of using with your style headers
AllDodge is offline
Old 07-08-2015, 02:21 PM
I also just use normal old fel pro exhaust gaskets from the local parts store. $20
92nsx is offline
Old 07-08-2015, 04:31 PM
SB
Received 3,116 Likes on 1,403 Posts
The two more typicallu sed Felpro's (there are more Felpro's with different sizes) Depending on cyl head exhaust port and header shape/size:
Felpro: 1410
Manifold Gasket Material : High Temp Fiber Facing w/Perforated Steel Core.
Manifold Gasket Port Height : 1.88"
Manifold Gasket Port Shape : Square.
Manifold Gasket Port Width : 1.88"
Contents : Exhaust Manifold/Header Gasket.
or
Felpro 1411
Manifold Gasket Port Diameter : 1.94"
Manifold Gasket Port Shape : Round.
Photos of 1410 first and then 1411
SB is offline
Old 07-22-2015, 11:08 AM
Thanks guys I used the felpro 17440 just cuz they say marine. no more leaks!
