Anyone add hydraulic bleeder tees?
30 spectre with marine machine hydraulic steering, aeroquip 401-6B fittings on hoses; Had to change one out, thought I had it bled pretty good but steering is sloppy. Wondering if anyone has added bleeder tees to a system like this. I haven't seen any tees with 45 deg SAE (5/8-18) threads. I think someone mentioned that the marine machine cylinders have 1/4 NPT fittings---could probably find a bleeder T to fit that. Wondering if anyone has blazed this trail, could point me in the right direction to find the part. thx
As long as you follow this procedure you should not need any other way to bleed.
http://www.everettperformance.com/PD...ING_SYSTEM.pdf
