Seller claims 454 Magnum 420hp stock - really? >
Old 09-18-2015, 05:50 PM
  #31
F-2 Speedy's Avatar
Received 3,048 Likes on 1,357 Posts
The gen 6 has an aluminum timing chain cover with the timing tab cast into it, with an O-ring seal to the block
F-2 Speedy is offline
Old 09-18-2015, 05:55 PM
  #32
and it has 6 bolts instead of 10.
mike tkach is offline
Old 09-18-2015, 06:39 PM
  #33
F-2 Speedy's Avatar
Was the gen 5 the first one piece rear main seal or six, trying to recharge the memory bank,
Old 09-18-2015, 06:51 PM
  #34
gen 5 was first for the 1 pc seal
snapmorgan is offline
Old 09-18-2015, 09:55 PM
  #35
If this guy produced a fresh 420 gen4 for a repower of a 1979 boat in the year 2012 guy may have some good connections. I wouldnt mind sitting down and having a beer with him. if it was pulled out of his cousins camaro, never mind.
airjunky is offline
Old 09-19-2015, 05:32 AM
  #36
SB
Received 3,115 Likes on 1,402 Posts
GM Performance Parts (GMPP) has a 454HO rated at 425hp. Lots of people by GM crate motors and drop them in boats. Psst: not saying if that's right ot wrong. Just making a simple statement.
Just a through thrown out of my head into the internet land. LOL.
SB is offline
Old 09-19-2015, 08:14 AM
  #37
well it is a good base to start w/ and for the few I saw,,the piston clearances were loose so thats why they survived.bearing clearances were a touch tighter than most of us use but a bigger cooler kept temps under control.
sutphen 30 is offline
Old 09-20-2015, 08:46 AM
  #38
KAAMA's Avatar
I only read a few posts within this thread,---I don't know what all was said previous to my post, but I hope that this might help a little in some way.
Anyway, If I remember correctly, the Merc 365hp 454cid engine is a 4-bolt main block with all Forged rotating assembly. They only come with the factory stamped steel rocker arms, sheet metal valve covers, Rochester Quadra-jet carb, and hyd flat tappet cam/lifters, but they DO have the GM rectangle port heads. The forged rotating assembly makes it a strong base engine for adding more hi-perf parts to it and kick up more HP.
KAAMA is offline
