Spring oilers
Spring oilers
Spring Oilers ... what are you guys that have them, using? And have you noticed any oil pressure drop, that is if you added them to an existing setup. Also have you noticed any benefit? I was thinking of adding them to my motors this winter. I was thinking about the flat plate ones that go under valve covers. I was going to tap a line off of my return line from my oil cooler, have that T off to the two plates. I was thinking of tapping the back side of the AN fitting Tee to fit carb jets, and start off with a .020 hole to start off.
Great Joe... any Idea what way your going? I think I will wait and make sure I get ahold of you before I pull the trigger on this one. Last upgrade I pulled to soon (MSD boxes)..LOL ... But I do love what they did for me
We have had the Eickert spring oiler system for about 8-10 yrs. However, it is hard to measure/prove exactly the benefit of spring oilers. All you know is that it can't hurt and that maybe your valve springs will remain cooler and last longer. I can say that our annual lash adjustments on our solid rollers never needed more than .000 to .001-.002 adjustment on a just a few lifters. We also checked the valve seating pressure annually and the seating pressure was always consistent. We also changed valve springs ever 30-40 hours. Does any of this prove that spring oilers are worth anything for valve train longevity in a marine application?......no but they can't hurt.
Ok that begs the question.... What is considered high RPM & you also have to factor in how long at what RPM? I know alot of guys that think running their motors up to 5500 for 10 minutes is long. Now go out on a big body water you could run for hours. I am also wondering if it will lower or raise oil temps?
HOLY $HIT 750 lift now I feel tiny at 650..... I will run 6300 till my oil temps get north of 260* then come down to 5500. I am also HYD roller whereas you must be solid. My spring pressure is 160 450ish you must be 200ish 750ish???????
I was just thinking about how motors are just like women..... If you don't spend enough money & time on them they. They end up being a pain in the ass.
