Adjusting Morel lifters revisited
My 489 has the Morel hyd roller lifters in it, and after doing some searches on here, I am well aware that these can sometimes be a little noisy, especially before the oil has heated up. When I adjusted them the first time with the engine build, I took them a little over a full turn after zero lash. Still, I have one or two that just sound overly noisy to me, even after the oil is up to 180* plus. This weekend I am thinking about checking things out just to be sure, and I thought I might try to identify the noisy ones and re-adjust them to see if I can get them to quiet down. My question is, what is the best way to approach this, and what procedure should I follow? I pretty much will have to run it with the valve cover off to identify the culprit, and I have an old stamped steel cover that has the top cut off of it to hopefully contain most of the mess. Once I identify the noisy one(s), should I adjust by backing off the nut and then tighten down until it quiets down, or is it better to adjust it with the engine shut down?
Anyone have a good procedure for both methods?
1 Full turn sounds like to much. According to the website and the thread pitch on my studs, I only turn them 5/8. I'm running Amsoil 15w-50 Dominator and my lifters are very quiet even on start up. It could be that I have a pre-oiler from Master-Lube that I use religiously. I would start checking your valve train for other issues. As a matter of fact the valve train on my BBC with a .623 lift is quieter than my wife's Northstar.
The technique I use, is to back off the rocker nuts and rotate the engine to allow the lifters to fully expand and then run through the firing order. I hand tighten the nuts until the push rods are hard to turn between my fingers and then add the 5/8 of a rotation. The lifters will compress down so the next run through the firing order I check the push rods to make sure they are not loose but still turn by hand. That way you make sure you haven't over compressed them or missed one altogether.
I have the 4603 morels in my engines. I adjust them to 1 full turn past zero lash. Very little noise. With less than that, they were a little noisier . Have ran nothing but 20w50 in them the past 4 years.
Same on icdedpples Hi Rev lifters. 1 turn past zero, his are quiet as well. Hes ran 15w50, 20w50, and straight 50 in his engines.
I adjust them by turning engine till exhaust valve just starts to open , and do that cylinders intake valve. Rotate again, and watch the intake valve open, and when it begins to close, i will adjust the exhaust on that cylinder. I do one cylinder at a time.
I've ran the Morel Hi-Rpms with sae 30,40,50 also 20/50. Never any noises. I've ran them with .000 .010 lash 1/8, 1/4 and 1/2 turn. I know Morel has a bulletin that says one full turn but I just could never see it. I never had any type of noise from the lifters. I did however soak them (can't remember what wt.) a few days before assembly.
My old SBC 4602 Morels were 1 turn. No problems. New lifters, soak for a day. Fire and run to operating temp. Shutdown and relash. Never have to adjust after unless the rockers come off.
