What do these bearings tell you?
#31
Charter Member#568
Some were uniformly coated in black just like the exhaust ports. Some looked like the one on the right which blows up well. I didn't notice any spots.
Straight bottoms and flat decks
#33
Charter Member#568
Like you said, a little lean. Doesn't seem like lean enough to kill it. The plugs and exhaust seem to show rich. Water temp never moved. Oil temp got up to about 240.
#34
Charter Member#568
I don't think I really have black stripes on the side of the pistons from lack of sealing. I think it's more like black scored and scuffed and burned aluminum from scraping the bores where those marks are visible.
#35
I've dealt with many motors that have been too lean while cruising and pig rich at WOT. Some vice versa too. Makes reasing things a little tougher without the right tools and references.
#37
Charter Member#568
I have the old style CMI big tubes. They don't have the necked down pipes/ flange. The primary pipes and flange are too big to bolt directly to the heads
#38
Charter Member#568
This is where a spark plug reading tool with magnifying glass and light can really help. IE: look thru the dark or blackness. By the looks of that picture showing the two middle cylinders on a low quality monitor, I'd be willing to bet you have some aluminum 'dust' (from your piston tops) in there.
#39
#40
Charter Member#568
I think someone mentioned earlier about oil being baked on to the bottom of the piston? This is the only pic of the bottom I have now. I'll get some more later
