Price to have motors pulled?
I prep everything for removal then call my local tow truck operator to bring his truck with the large boom and we remove the engines in about 1/2 hr. each. Cost me about $100.
Not high enough to pull the engines on my 32 AT, but probably would have worked for my 28 Pantera.
I have the harbor freight one. There are 8 bolt holes at the top that hold the I-beam to the frame. I basically slid the beam over one bolt hole so that only 6 bolts are holding it. That buys you several inches on both sides. The width between mine is 103.5 inches.
My cafe tapers in the back so it wasn't a problem even at the normal install method, but I just spread it to give me some extra space.
I also have the harbor freight trolley and chain hoist. A nice adjustable spreader bar is also worth the 50 bucks.
I've pulled and r&r'd my engines about a dozen times in the last few years and will be doing so next weekend. Once you've done it you realize it is easier than winterizing it. I'll have both of them on the ground in the garage before lunch including crane set up, hatch removal, etc. if you have the place to do it, it's a real money saving skillset
If not already mentioned, rent a forklift with a fork extension. Rent for around 250-300 per day.
[ATTACH=CONFIG]546353[/ATTACH]
Notice the height, this thing is huge. I didn't document exact cost but do remember it being around $200 for wood and galvanized hardware. It's stores easy against a wall when dismantled.
